Dear Expert, I have a simple C program with 'linklist' data structure processing as below. ////////////////////////////////////// #include <stdio.h> #include <stdlib.h> typedef struct node{ unsigned int id; struct node * next; }; void main(void){ struct node * first; struct node * n; unsigned int i; printf("/////////////////\r\n"); first->next = (struct node *) malloc(sizeof(struct node) * 10); if(first->next == NULL)printf("** Not enough memory space\r\n"); printf("first->next %X\r\n",first->next); first = NULL; //no first link for(i=1;i<=10;i++){ n->id = i; n->next = first; first = n; }; while(first != NULL){ printf("n->id = %X , n->next %X\r\n",first->id,first->next); first = first->next; } free(first); } ///////////////////// When I run this program , the result is unterminate loop. But I try to test this program on Turbo C++ when including "malloc.h" , it is work and result is correct! What wrong with this codeing? Then,I wonder does C51 support link list data processing? I will looking forward your reply and thank you for all suggestion. Birdy.
Hi Natahn, You didn't use init_mempool function. This may be the cause for your problems. Please read about it in the C51 compiler UG. Regards, Amit.
'Link List', malloc(). You are clearly writing your program under the assumption the the '51 is "just another" processor. It is not, is is an "archtecturally different from most" processor. Keil has (out of kindness of reacting to customer pressure) added the necessary to use it as "just another", but that will lead to a dramatically underperforming (more hardware needed to do less) product. Erik
"'Link List', malloc()." Linked Lists do not inherently rely upon dynamic allocation, and can be quite useful even on an 8051; eg, http://www.8052.com/forum/read.phtml?id=70144 http://www.8052.com/forum/read.phtml?id=33232 "You are clearly writing your program under the assumption the the '51 is 'just another' processor. It is not, is is an 'archtecturally different from most' processor." Actually, the reasons why malloc() is generally avoided in embedded systems have nothing to do with the 8051 architecture - they apply equally to all the other processors that are not 'archtecturally different from most'
Linked Lists do not inherently rely upon dynamic allocation, and can be quite useful even on an 8051; useful, maybe, efficient no. A liked list is pointer to pointer to pointer to ..... which is not candy to a '51. why malloc() is generally avoided in embedded systems have nothing to do with the 8051 architecture agreed, it should be generally avoided, just as a lot of other "standard" things this is worse in a '51 than in most. I love the '51 and it performs beautifully when used as a '51, but when somone treat is as a "small PC" it sucks because it is so good at what is is intended for. Erik
