i'm using keil as development tool for msc 1210. i want to generatehex file for this code(with assembly codes); what do i need to do, " #include<REG1210.H> void main(void) { while(1) { P2=0xfe; #pragma asm mov P0,#3fh #pragma endasm } } " i have included assemly code option from "LISTING" option from " OPTIONS FOR TARGET".But i get errors. need a quick help!
You need to use #pragma SRC when you compile to generate a .SRC file. This file contains your inline assembly and can be assembled with the A51 assembler. Jon
