Who Controls the Baud Rate???
It appears that when you intialize a baud rate thru the debugger... mode com1 19200...
If you set your COM port settings in windows to 57600, the data still transfers at 19200. Is there any way to have Windows control the baud rate instead of the debugger. For instance, I would set the baud rate in the debugger to some dummy value, and have windows control the actual baud rate that I want to transfer at.
I am posting this because I would like to transfer at 115200, and I cannot input this value into my debugger.
