Assembly routines producing NOP's
I'm new to the Keil compiler and am having problems with assembly subroutines. The program compiles and links just fine but when I download the debug file to my Metalink emulator the assembly subroutines show up has NOP's. Here's the C section:
if (have_ram)           /* if ram available save cause of reset*/
		Chk_reg();			/* check if buffer variables are ok*/
		if (WTRF)			/* watchdog timeout*/
			wdrst++;		/* increment number of times watchdog has occured*/
			WTRF=0;			/* clear flag*/
		trst++;				/* increment total number of resets counter*/
		Lrc_reg();			/* calculate new storage reg LRC*/
and here is the assembly routine:
$TITLE(LRC_REG)
PUBLIC  LRC_REG
DPL1		EQU	84H
DPH1		EQU	85H
LRC_REG	SEGMENT	CODE
	RSEG	LRC_REG
	MOV		DPTR,#7FE0H	; start location of buffer
	MOV		B,#00H		; clear
LRC1:
	MOVX		A,@DPTR		; load data
	XRL		A,B		; exclusive OR
	MOV		B,A		; store
	INC		DPTR		; next location
	MOV		A,DPL1		; check for end of buffer
	CJNE		A,#0F7H,LRC1    ; loop if not end
	MOV		A,B		; get computed checksum
	CPL		A               ; compliment for cleared RAM
	MOVX		@DPTR,A		; store new checksum
	RET
	END
This is the assembly code it ends up producing:
48B4    LRC_REG: NOP
                 NOP
                 NOP
It is doing this for multiple assembly subroutines. I know I'm doing something stupid but don't know what it is.
  • Use the "Generate Assembly SRC file" option on a fuction header to get you prototype for you assembly functions.
    This:
    void Lrc_reg( void ){}
    Generates:
    ; .\Main.SRC generated from: Main.c
    NAME	MAIN
    ?PR?Lrc_reg?MAIN     SEGMENT CODE
    	PUBLIC	Lrc_reg
    ; void Lrc_reg( void ){}
    	RSEG  ?PR?Lrc_reg?MAIN
    Lrc_reg:
    			; SOURCE LINE # 1
    ?C0001:
    	RET
    ; END OF Lrc_reg
    	END
    Now just add your code.
    This:
    Generates:
    NAME	MAIN
    	PUBLIC	Lrc_reg
    Lrc_reg:
    			; SOURCE LINE # 1
    ?C0001:
    	RET
    ; END OF Lrc_reg
    	END
