I use this code:
#include <reg52.h> void main(void) { unsigned char data x8,x9,x10; while(1) { x8 = 0; x9 = 9; x10 = x8 + x9; __asm CLR A; } }
; void main(void) RSEG ?PR?main?MAIN main: USING 0 ; SOURCE LINE # 5 ; { ; SOURCE LINE # 6 ?C0001: ; unsigned char data x8,x9,x10; ; while(1) ; SOURCE LINE # 8 ; { ; SOURCE LINE # 9 ; x8 = 0; ; SOURCE LINE # 10 ;---- Variable 'x8?040' assigned to Register 'R7' ---- CLR A MOV R7,A ; x9 = 9; ; SOURCE LINE # 11 ;---- Variable 'x9?041' assigned to Register 'R6' ---- MOV R6,#09H ; x10 = x8 + x9; ; SOURCE LINE # 12 ADD A,R6 MOV x10?042,A ; __asm CLR A; CLR A; ; } ; SOURCE LINE # 14 SJMP ?C0001 RET ; END OF main END
C_STARTUP: C:0x0000 020003 LJMP STARTUP1(C:0003) STARTUP1: C:0x0003 787F MOV R0,#0x7F C:0x0005 E4 CLR A IDATALOOP: C:0x0006 F6 MOV @R0,A C:0x0007 D8FD DJNZ R0,IDATALOOP(C:0006) C:0x0009 758108 MOV SP(0x81),#0x08 C:0x000C 020000 LJMP C_STARTUP(C:0000)========>You see here!!! MAIN: C:0x000F E4 CLR A C:0x0010 FF MOV R7,A C:0x0011 7E09 MOV R6,#0x09 C:0x0013 2E ADD A,R6 C:0x0014 F508 MOV 0x08,A C:0x0016 E4 CLR A C:0x0017 80F6 SJMP MAIN(C:000F) C:0x0019 22 RET
The code is right, what do you think is wrong? If you don't use optimizing, you will see that x8 was assigned an address of 8 and x9 of 9, and x10 of 10. But if you use high level optimizing, the compiler will use some registers assign to the local variables, as in the target file, the x8 was r7, and x9 is r6, but x10 was kept as a non-register varable still and its address was 8. The first 'CLR A' was used to generate a zero for the operation 'X8=0', and the second one was generated by your __asm.
I means that the debug is wrong. You can see the common I add there, it should not be that: But, when Debug it, it like like this in debug window:
In my debug windows, it shows:
C:0x0009 75 81 08 MOV SP(0x81), #0x08 C:0x000C 02 00 0F LJMP MAIN(C:000F) C:0x000F E4 CLR A <==== MAIN
What linker errors did you receive? Jon
No errors, just warrings:
Build target 'Target 1' compiling main.c... assembling main.src... linking... *** WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: ?C_STARTUP MODULE: main.obj (MAIN) creating hex file from "c_asm"... "c_asm" - 0 Error(s), 1 Warning(s).
Ahhhh. This warning indicates what the problem is. It is usually NOT SAFE to ignore linker errors or warnings. The problem is that you have no C modules in your program. Since you use the SRC directive to get an assembler module (from a C module) the program is really an assembler program. In such a case, you must manually include the correct C library to get the startup and initialization code routines. Refer to the following knowledgebase article for details on how to do that. http://www.keil.com/support/docs/1646.htm Larger programs with a few inline assembler modules will not exhibit this problem since there is likely to be at least one C module. Jon
Thanks a lot. I add c51s.lib into my test project, and it seems everything is OK.
