Hi, Is there a means of supressing linker generated warnings? I realise they're there for a reason, but this one's deliberate. I forget the error code, but it's concerned with the location of an interrupt routine within a code bank. It never gets called in a bank switched context, but the routine is copied across to RAM as part of a flash download routine. Thanks, David
Very true, Erik! My previous Client's build routinely spewed out hundreds of warnings, most of which were harmless. I found at least 3 of them which were real bugs!
Beware! I have seen projects where I were called in to rescue where the problem was found easily by removing warning suppressions. While some warnings may be innocent it is very dangerous to disable them (globally). I suggest you live with the message rather than suppressing all warnings. Erik
Look on the 'BL51 Misc' tab
