C51 V6.20 & V6.21 still have reported bug
On Nov. 11, 2001, I sent in a C51 V6.20 bug report via e-mail to support.us@keil.com. I never received a response, so assumed Keil's policy was to silently introduce the bug fix in a subsequent update. After downloading V6.21, I see that the bug is still present. Now I'm wondering whether my e-mailed bug report was ever acted upon, so I'm going to try the forum as the means to report the bug.
I have a section of code with pointer incrementation that compiles and executes correctly when the pointer is defined as a generic pointer or as an xdata pointer, or when the optimization setting is reduced from the default OT(8,SPEED) to OT(7,SPEED). However, when the pointer is defined as a data or idata pointer, the compiler does not emit code to increment the pointer with default optimization.
I have provided example code demonstrating the problem. The specific statement is line 50 below.
unsigned char idata u64[8] = { 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF };
unsigned char idata s[21];
void U64ToStr( char idata *s, unsigned char idata *binP, unsigned char n )
    unsigned char        bcd;
    unsigned char idata *bcdP;
    unsigned char        bitMsk = 0x80;
    unsigned char        carry;
    unsigned char        i;
    /*  Zero the target buffer (NUL-terminating the string).
    for (bcdP = s, i = n + 1; i != 0; *bcdP++ = 0, i--)
    /*  Convert 64 bits of binary to unpacked BCD.  For each bit, starting
     *  with the MSBit, BCD = (BCD * 2) + bit.
    for (i = 64; i != 0; i--)
        carry = (*binP & bitMsk) ? 1 : 0;
        for (bcdP = s + n; bcdP != s; /* Iter in body */)
            bcd  = *--bcdP * 2;
            bcd += carry;
            if (bcd < 10)
                carry = 0;
            else
                carry = 1;
                bcd  -= 10;
            *bcdP = bcd;
        if ((bitMsk >>= 1) == 0)
            bitMsk = 0x80;
            binP++;
    /*  ASCII'fy BCD.
    for (i = n; i != 0; i--)
        *bcdP++ += '0'; /* <-- C51 BUG: bcdP doesn't increment for (i)data */
void main( void )
    for (;;)
        U64ToStr( s, u64, 6 );
--Dan Henry
