Hello, I'm using C51 V4.01 Keil compiler. When I compile a .C file (with c51.exe), I obtain a .lst file and not a .O51 file. In the .lst file it writes "No object module requested". My question is How can I obtain a .O51 file? What compiler configuration file (if does exists such file) should I change and how to do it? Thank you.
Any particular reason why you're using such an old compiler?!
