sizeof bugs...
As we all know... sizeof( typedef ) should return the size, in bytes, of its operand. If the operand is a type, such as a float, it must be enclosed in parentheses.
I found a bug in sizeof( tMyStruct ), where tMyStruct is a structure I typedef'ed that included an enum. sizeof was returning a value off by one from what I expected. This problem went away after replacing the enum with an unsigned int--both of which are supposed to be two bytes in size.
It appears that an enum is only one byte and not two bytes as documented in the C51 Compiler manual. In an attempt to verify this I tried sizeof( enum ). However, this produced a syntax error instead of returning the size of the operand. A second bug.
Can anyone else verify this... I'm using uVision2 v2.20a with C51 v6.20c.
Regards,
Mark Shelton
Remove "nospam." from the domain of my e-mail address to reply directly.
