Debug ok but hexfile not.
I am playing with demo version of the Keil µVersion 2.03 and the
Infineon SK-167SR. Also , I am not very familair with in C, which
makes thinks not easier for me.
For me the problem is rather strange. During a debug session
almost every thing is runining fine, but if i let the same programm
run from the flash of the board it does not.
here is (not) working code
void main(void)
unsigned char num_str[6];
... do soemthing ...
write_string(num_str,1);
void write_string(char * s, unsigned char line)
unsigned int i;
if (line == 1) LCD_CNTL = 0x80;
wait(30000);
for (i=0; i<strlen(s); i++)
LCD_DATA = s[i];
wait(300);
During debuging this is working perfectly. It shows some data on a LCD,
but the same program running from flash, writes "only" black squares
on the LCD (the complete fist line on my 20*2 LCD).
For me it is quite hard to find the reason for this behavior.
thanks in advance,
Thomas
  • void main(void)
    What happens after write_string returns?
    If your program returns from main, then it's no surprise that it doesn't work when you run it from FLASH.
    Add a while (1) before the final curly brace in the main function. (Embedded programs never exit).
    Jon
  • void main(void)
    Jon
