When i use external memory, port 0 and 2 will be used for data and addressing, so i'll be left with only the serial port and port 1. I open to suggestion on ways to add another two I/O ports. Thanks
You need to use memory mapped I/O for additional ports. This will require adding some decode hardware, and the ports themselves (flip-flops, latches, etc.). They would interface just as an external memory chip would. Typically you would set up a range of addresses and decode chip selects with a PAL. Pay close attention to the timing of the 251, and how it accesses memory with different instructions. You should set up some test cases for accessing these ports, and look at the instructions. The simulator DOES NOT add any clock cycles for addressing external memory - this can lead to severe timing differences if you're trying to get an idea of performance. This caused us some grief in our project.
