Hello, I've been trying to understand how to configure the memory on my Cypress AN2131 EZ_USB Development Kit, using the Keil Debugger interface, and I am struggling to get it to work. I find that Malloc will not work when called from my C code. I intend to try to use the small model, with all my data variables in the first 6.8k of internal memory space, and with up to 64k of external program memory. Also I hope to use a lot of pointers to access two-dimensional linked lists held within AN2131 Internal memory, and I am finding that fairly simple lines of C code result in 20 or more hex bytes. Is this as to be expected, or is there a compiler option which I am missing. I'd be grateful for any help, Andrew Murray
1) Did you call "init_mempool" before calling "malloc"? 2) Using since xdata pointers use the single DPTR register, code can get pretty big. One painful option is to use pdata in conjuntion with the MPAGE register. This requires more programming on your part, because you must handle this page register.
