I am in need of detailed help. I hope someone has the kindness to walk me through this. I have the MCB167-NET board, which contains a Flash module from AMD (AM29F040B-90JI). I want to be able to run the BLINKY program straight from FLASH, without having to hook it up via serial port to my computer and do all the compiling, bootloader stuff. I want to be able to power up the eval board and automatically see the BLINKY program execute by seeing the led lights turn on. How do I get the program into FLASH? What are the steps? If I have to write a program, is there something I can follow as an example program that you recommend? I'm obviously new to this, but would like to learn. Please help me.
You must write two programs: Bootstrap Preloader and Flash Loader. Bootstrap Preloader must have size 32KByte strongly and it missing is to load Flash Loader into IRAM or external RAM if your board have it. Flash Loader having booted and having received handle from Preloader will load hex-file into your flash. To write Flash Loader read respective datasheet.
Check the board vendor's website - they might have something. Also check this site, the Keil CD, and the processor vendor's site.
You might want to have a look at the following pages: http://www.hitex.co.uk/c166/utilities.html http://www.hitex.co.uk/download/btld/btld.html Take care! Mike.
