Is it possible using the C16x tools to create a variable that's a pointer to an sbit? I'm trying to find a way to allow a function in a custom library to not need to know where an I/O pin is until the user of the library informs it via a library initialization function call. For example, if there was a blink LED function, where that LED was on a different I/O port pin on different pcbs, the user of the library could inform the library function where the I/O pin was, by passing it the address of the sfr bit. It seems to me that in order to be able to make this work, I need to be able to create a "pointer to sbit" type of variable in my library. Help, Dave.
As it is said in C166 compiler description, pointers to bits are not supported (which is easy to understand: there are no such instructions in C166/C167 instruction set). It seems that the only way to do what you want is to pass to the library function address of I/O port and bit number. For example: void SetPortBit(int* PortAddress, int BitNumber) { *PortAddress |= (1 << BitNumber); } void main(void) { DP2 = 0xFFFF; SetPortBit(&P2, 15); }
Thanks...! I was pretty sure I remembered reading that somewhere in the C166 manual, but I didn't find that text when I went back and looked for it. Your suggestion will probably work just fine for what I want to do. Thanks again, Dave.
You can create an EXTERNAL definition for the bit in your library. Then, in your main program, declare the bit. Refer to the following for an example of doing this with the 8051 tools: http://www.keil.com/support/docs/168.htm Jon
