Check/locate Stack
How is it possible to locate the stack
(both internal and extended).
Whow is it possible to check the size of
allocated memory ?
I would like also to put stack (only) in
extended memory.
Actually I have some problems with
stacks overflow.
Thank you,
Dimitris
  • How is it possible to locate the stack
    (both internal and extended).....
    stacks overflow.
    Stack overflow is NOT related to the stack, it is related to the excessive use of variables on DATA and IDATA.
    While there are memory models that will allow you to create a pseudostack in XDATA, you will be far better off moving some of your rarely accessed variables to XDATA.
