Monitor-166 AND RTX166
My Target has 256kB FLASH at CS0 and 256kB RAM at CS1.
The Monitor-Code is at 3C000H and the Monitor-Data is at 3E000H.
The Version of RTX-166 : V4.01
The Keil Developmet Tools Release : 05.2001
The CPU : C167CR-LM
My Problems are :
- The functions in the modul <start167.a66> delete the wrong memory
if the switch "CLR_MEMORY" is set.
- The function os_start_system() return FFFFH in R4 or it doesn't
come back.
My Question is how must the Monitor be configured to works correct,
how must the RTX-166 be configured to start correctly and how must
I the CLASSES NCODE, ICODE, FDATA, ... adjust.
Best regards Reinhard Woeber
