Hi everybody, I am using ISD51 with the Philips MCU P89C668. This MCU does not support HW breakpoints and I cannot use soft breakpoints since they slow the program down by a factor 100, which is not so good when developing hard real-time drivers. So the only viable approach for me is to use hard coded breakpoints through the macro ISDbreak. I have the system running with ISD51 included (using baud rate 38.4 kbps). My problem is that ISDbreak does not halt execution immediately. It seems like 20-30 instructions are executed after ISDbreak prior to stopping execution. It is hard to work with breakpoints that does not stop execution immediately. Have any of you developers out there experienced the same problem? Any solutions or suggestions? Best regards Björn Strandmark
ISDbreak needs an enabled interrupt system. See also: http://www.keil.com/support/man/docs/isd51/isd51_isdbreak.htm
Bjorn, I have found exactly the same thing, on my ST uPSD3200 part. In fact ISDbreak() does not always stop the execution, and can lead to some peculiar results. If anyone has oversome this problem I would be grateful if they can help here. How did you get on with your development Bjorn, as I see you originally posted some months ago? Thanks, Gary
