I want to setup the fast external interrupt 0 (EXI0)on the Infineon XC16x board (pin P1H.0). My functions look like this:
void EXI0_Int (void) interrupt 24 { // Interrupt routine } void EXI0_Init (void) { EXICON |= 0x02; // Falling edge EXI0 CC1_CC8IC = CALC_IC (0, 1, 13, 0); // ILVL = 13, Interrupt enable PSW_IEN = 1; }
Hallo! Did you find a solution? I need the EX1IN too anf it also doesn't work! Please send me your working example!
You can use the code generated by DAVE (command 0 to 4 as described in the SU user's manual) to get write access to the EXICON register after the EINIT (end of initialization) instruction has been executed:
// Unlock procedure void MAIN_vUnlockProtecReg(void) { unsigned char ubPASSWORD; //if low protected mode if((SCUSLS & 0x1800) == 0x0800) { ubPASSWORD = SCUSLS & 0x00FF; ubPASSWORD = ~ubPASSWORD; SCUSLC = 0x8E00 | ubPASSWORD; //command 4 } //if write protected mode if((SCUSLS & 0x1800) == 0x1800) { SCUSLC = 0xAAAA; //command0 SCUSLC = 0x5554; //command1 ubPASSWORD = SCUSLS & 0x00FF; ubPASSWORD = ~ubPASSWORD; SCUSLC = 0x9600 | ubPASSWORD; //command 2 SCUSLC = 0x0800; //command 3 ubPASSWORD = SCUSLS & 0x00FF; ubPASSWORD = ~ubPASSWORD; SCUSLC = 0x8E00 | ubPASSWORD; //command 4 } }
Thanks a lot! This was the problem! After I used the unprotected algorithm it works perfectly!
