Problems using 2nd CAN Controller on Phytec Minimodul C167CS
Hello!
I've a lot of trouble with the second CAN controller on a phytec minimodul with a
C167CS.
The first CAN Controller works fine, no problems. But when I try to use the second
CAN controller, I got nothing on the pins. I tried port 4 (IPC = 0) and also on port 8.
The direction for the ports is correct, but the pins seem to be dead (no signal on).
When I test the portpins with digital I/O, the work correct. The CAN2 is enabled in
SYSCON3. ISR for the 2nd CAN is implemented, 1 transmit message declared.
Is there anything more to do? An special bit to set for the second controller?
I tried DAVE, to see, if there's something more, but I didn't find anything, which
helped me.
Maybe someone has a hint or link for me ...
Have a nice day!
SVEN
P.S.:
I know the keil/infineon application note, but the all use only the first controller!
