hi all, I have the following line in my code: PortVal << 1; When I compile using c51 v6.12, I get the following warning assocaiated with that line: "warning C275: expression with possibly no effect" When I load this into my emulator, "PortVal << 1" has been optimized away. I know that << 1 is the same as *2, and when I use *2, the compilier is happy, but I like << 1 because it helps readability..... Does anyone know why << 1 causes that warning or how to prevent it from being optimized away? Thanks Steve
You should write PortVal << =1;
The warning has nothing whatsoever to do with << vs. * --- you should actually have got it for the *2 case, too. The warning complains about "no effect" because that's what this really is: a statement that doesn't do anything. It computes a value that's not used for anything. This can usually have two reasons, one of which is an outright bug in the code. The other would be an expression being compute only for its side effects. But the expression shown doesn't have any, so that's pretty much ruled out. Conclusion: that warning is valid. You should probably re-write that line or remove.
PortVal <<= did the trick! I looked in K&R and they dont show <<=. It just shows val << 1. Anyway..... Yes, that fixed it. Thanks, Steve
Your right....my bad....typo in my email. The line is written PortVal *= 2. Thats why the compilier doesnt complain. I agree that if it was *2, the compiler would point that out to me. I just looked in "C The Complete Reference" and they dont show this construct as <<= either; they just show it as <<. Hmmmm. Interesting. Anyway, thanks again for all the help.
The <<= operator is listed in K&R. You just have to read the section on Assignment Operators and Expressions (section 2.10) very carefully. "...Most binary operators...have a corresponding assignment operator op=, where op is one of + - * / % << >> & ^ | ..." Jon
"<<" is an operator, the same as "*". So var = var * 2 is the same as var *= 2 and var = var << 1 is the same as var <<= 1
