Under the project options - target - external memory section, does the 'size' field represent 8-bit or 16-bit values; and does the external bus mode play a part in specifying this value. For example, if I'm using a 16-bit non-mux'd data bus, with a 32Kx16 SRAM at some address, should the size for that SRAM be spec'd as 0x8000 or 0x10000? Thanks.
The size is in bytes, as always. does the external bus mode play a part in specifying this value No, it does not. For example, if I'm using a 16-bit non-mux'd data bus, with a 32Kx16 SRAM at some address, should the size for that SRAM be spec'd as 0x8000 or 0x10000? 0x10000 - mike
Thanks for the answer. I did check the paper and e-doc's (before posting online) for the answer, but couldn't find a clear and definitive answer. Even the answer in the "knowledge base" was a little fuzzy [to me]. In it's example it used a RAM (of unknown data bus width) whose address spanned 0xFFFF, and then stated that the "size" field should be set to 0x10000. That seems to be 1/2 what you think it should be.
