Avoiding warning L16
Is there a way to avoid the following warning: Warning L16: uncalled segment, ignored for overlay process? I'm not talking about the Disable warning numbers you have in the options of a project...
I know what the overlay process does, but if the function is indeed not called (and there could be reasons not to call a function for a certain application), is there not a kind of 'dead code remover' who can check if a function is called or not?
If so, is this function not able to inform the compiler just to ignore this function and not to generate the warning?
Rgds,
Geert
