Different .HEX code when Assembler SRC is selected C51 V6.10
Is there a bug? I have a well debugged and tested C program, that works fine with a normal compile. (Optimization Level 8, emphasis on code size ) It does not work correct when I enable the Assembler SRC generation and assemble the SRC files.
The bytes of code generated are exactly the same, but a comparison of the 2 resultant *.HEX files shows some differences. The differences occur near the beginning of the .hex file, and then the files are identical for the rest of the 3600+ bytes. Can anyone help?
