On C167CR I have created a project witch Dave2.1 and I have 20 address lines (A0..A19). I want to compile but uVision does not leave me compile more than 64K. How can I simulate before reset configuration pull-down resistors with uVision and so create a good H86 for my number of address lines. Thanks!!
Are you using small memory model? Small memory model restricts code size to 64K bytes, if all functions are 'near' (as they are by default in this memory model.)
I'm not working with small memory model, anybody knows the solution of my problem?
Switch to MEDIUM. If it doesn't work (too much data), switch to LARGE memory model. The memory model setting is in the target options dialog.
I'm sorry, my mistake. I didn't pay enough attention. What's exactly the problem? Any error/warning messages from the compiler/linker?
Thank you very much for your valuable help! This is the response I have from the compiler: assembling: starta167.a66 compiling: main.c... c:\main.c: error C8: code size exceeds 64K Target not created The program is in Large memory model,The external memory settings are: ROM: Start(0x0000) Size (0x20000) I have On Chip XRAM+CAN checked In L166Locate tab I have Use memory layout from target dialog checked and in target classes appears the next text: ICODE (0x0-0xEFFF), FCODE (0x0-0xEFFF, 0x10000-0x1FFFF), FCONST (0x0-0xEFFF, 0x10000-0x1FFFF), HCONST (0x0-0xEFFF, 0x10000-0x1FFFF), Thanks!!
Here are 2 things that I notice about application. 1. Only use LARGE model if you use a 80C166 device. For all other C16x devices use the HLARGE model. It is more efficient. 2. It sounds like you have a single C file that generates more than 64K of code. The description for the error message is pretty descriptive: Code size exceeds 64K The maximum code size per module is 64K bytes. Jon
Thank you very much!! I have splitted the code into two files and I have a correct compilation.
