22 doubts in basics of 8051
Hi 8051 experts
please help me understanding following:-
1. which was the first microcontroller
2. what does legacy port means
3. what is pulse width modulator
4. what is phase locked loops
5. what is minimum time for level triggering in 8051
6. what are usual applications of 8051
7. what does DPTR contains
8. why bit addressable SFRs are at addresses ending with 0 or 8
9. when we use timer in mode 0 it is 5 bit prescaler. what
exactly it means
10. how PD and IDL can be tested in PCON
11. how to use "user definable" flag in PSW
12. I wrote a simple program to do serial transmission. the code is
hereunder:
#include <REG51.h>
void main()
TMOD=0x10;
TR1=1;
SBUF='C';
when I m testing this program in simulator it is again and again
jumping to main itself. means transmitting C again and again. what
could be the reason.
13. where does interrupt destination like IE0=0003 lies RAM or ROM,
14. when we make an ISR interrupt value can be from 0 - 31, why 32 values when we have got just 5+1 interrupts
15. what r different addessing modes in 8051
16. can uC access Data memory and Code memory at same time.if yes,
is it also possible for extenal RAM and ROM
17. when we use timer0 in mode 3 , it get divided into two 8bit
timers, lower timer is started by setting 1 in TR0 sfr. and upper
is started by setting 1 in TR1 sfr. but basically TR1 is used for
Timer1. so will timer 1 also run at that time.
18. when we create a new project in Keil IDE, there remains an
option as "use extended linker(LX51)instead of BL51". kindly throw
some light on this.
19. how parrallel communication happens with external devices. why
there is no need for baud rate. does bits in one wire of parallel
port go one after another like serial or there is some ACK
mechanism.
20. in case of keil 8051, what goes in Stack. where global variables
remain.
21. what are different uses of 4 banks in 8051
22. what is version of keil compiler and what is the way to check
it.
