Beginners question; RD/WR doesn´t work
I have quite recently started working with uVision and an Atmel MCU, and I think that I may have done something wrong in my settings... Here goes:
The problem is that both RD and WR goes low when I try to read or write.
My hardware is an Atmel T89C51RD2 MCU, and it doesn't matter that I set the AUXR register EXTRAM bit to one - the RD/WR toggles and both are low at the same time.
My code looks good enough; the write cycle assembler code looks as follows:
C:0x0015    9098FC   MOV      DPTR,#addressbyte(0x98FC)
C:0x0018    7401     MOV      A,#0x01
C:0x001A    F0       MOVX     @DPTR,A
So both the address and the data are correct.
My target options has been a lot of different. I really do not know what to do with them - aren't a lot of them set in the STARTUP.A51 file? do I need to set them at more places?
Anybody that has experienced the same or similar problem?
Most grateful for help.
