question on structures
Hi all,
I'm coding graphic LCD routines and I want to include several text fonts.
So, I've defined a structure as :
typedef struct DEF_FONT
	U8 u8width;     /* Character width*/
	U8 u8height;  /* Character height*/
	U8 *au8fontTable;       /* Font table start address in memory  */
} DEF_FONT;
then, I've included two fonts and they are declared like this :
struct DEF_FONT code Font_System5x8 = {5, 8, au8font5x8};
struct DEF_FONT code Font_System8x8 = {8, 8, au8font8x8};
Now, I want to print a text with a selected font.
I've tried to send the structure as a parameter in the GLCD_PutChar function as :
void LcdPutchar (U8 u8Char, DEF_FONT stFont)
and then, I've tried to access the elements of the structure in the function like this :
LcdDataWrite (stFont->au8fontTable[(u8Char - 32) * 5 + u8CharColumn]);
There is an error from compiler
***ÿERROR 199 IN LINE 345 OF C:\TRX8051\GLCD.C: left side of '->' requires struct/union pointer
I suppose the solution may be to declare in the function a pointer to the structure like this:
struct DEF_FONT *ptr
I understand how to use it in a single structure, but in this case, how is done the selection of the font between the two structures ?
Regards
Stephane
  • You need to correct the second parameter's type:
    void LcdPutchar (U8 u8Char, DEF_FONT *stFont)
    If I understood your question correctly, it would be the responsibility of LcdPutchar()'s caller to select between the two structures and pass a pointer to the appropriate one, as in:
    LcdPutchar('5', &Font_System5x8);
    LcdPutchar('8', &Font_System8x8);
