xdata and compact memory model
If I'm using the compact memory model, which implicitly sticks variables in xdata, but also declare a variable (in this case a char[]) to go in xdata, it appears to use the wrong pointer type. Thus, I get the lower 8 bits if the address, NOT the data.
Not explicitly declaring the variable as xdata yields the correct result.
Is it me or the compiler?
