Enums and Ints
Bug, or just weird subtlety of ANSI C when it comes to enums and ints?
typedef enum
    es16_1, es16_2, es16_3,
    es16_Force16 = 0x7fff
    } EnumS16;
typedef enum
    eu16_1, eu16_2, eu16_3,
    eu16_Force16 = 0xffff
    } EnumU16;
According to C51 7.02b, the sizeof(EnumS16)== 2, as you would expect. Sizeof(EnumU16) == 1, however.
Is this a compiler bug? Or a result of ANSI C integer/enum rules? Enums, after all, are a kind of int (as opposed to "unsigned int"). It would be reasonable, then, to reject the explicit value of "0xffff" as unrepresentable, and generate a compiler error. But the code compiles. So, you might consider 0xffff to be the hard way to write "-1" -- but it's still 16 bits wide. On the other hand, perhaps it's just considered -1, and represented as 0xff in a 1-byte integer, which the enum would otherwise allow. On the third hand, ANSI C doesn't allow for variable-sized enums anyway (though any decent embedded compiler does), so perhaps the interpretation is up to Keil.
I'd think the second example rates at least a warning message; it surprised me, anyway.
  • This is all speculation but I vote for your first hand.
    The C166 manual (I assume the rules would be the same for the Cx51) says that enum types are 16-bit from -32768 to +32767. So it seems reasonable that the compiler rejects the 0xffff and reverts to a 1 byte size. My only explaination on why you don't get a compiler error is perhaps that you are not using eu16_Force16???
    -Walt
