Using Tiny TCP/IP Stack (APNT_164) MCB167-Net evaluation board
I am evaluating this Tiny TCP/IP Stack on MCB167-NET which has a CS8900 Ethernet chip on-board.
My software runs perfectly well in Keil debugger, with the capability to connect to the PC server through TCP/IP.
However, when the code is programmed into external flash, the program do a forever loop at this statement at Init8900(void) under CS8900.c file!!!
while (!(Read8900(DATA_PORT) & INIT_DONE))
This statement is trying to wait until chip-reset is done. The value obtained when running on external flash is always 0x5555H.
All parts of the programs is able to run if I temporarily remove this statement, except the TCP/IP communication. I presume the flash programing is working well then. :)
May anybody or Keil with experience on these help me to solve this issue??
Many Thanks!!
