Why not printf works always.... When I tried with Keil Monotor Driver51 it did not work but was working in simulation mode. But now again when I try to debug sample code in simulated mode it does not work....
Is the monitor using the serial port, so that it's no longer available to printf?
sir i am lookin for a 'C'program to test two channels of 12bit adc(internal)with looping back with 12bit dac(internal)using C80510F20 in 'C' PROGRAM. OR PLEASE TELL ME THE PLACE WHERE I CAN GET A C PROGRAM TO READ 8 CHANNELS OF ADC IN INTERRUPT MODE FOR ALL THE CHANNELS AT MAXIMUM SPEED.PLEASE CONSIDER THIS LETTER AS SOS AND REPLY REGARDS VSRAO EMAIL ADDRESS:vsrao_2k@yahoo.com
vs rao, Your request appears to have nothing to do with this thread - "Why not printf works always...." You are much more likely to get a response if you start a new Thread for your request! Also, avoid the use of ALL CAPITALS - this is often considered to be SHOUTING and, therefore, rude.
