I use keil51 to compile some .asm files included in my project, but the "$CASE " can not be accept by keil51. I am puzzled!
"I use keil51" There is no such product! I presume you mean the Keil A51 or AX51 Assembler? "compile some .asm files" .asm are normally assembler files - you cannot compile them! Look at the manual - what does it say? "CASE (AX51 and A251 only)" Are you using AX51 or A251? If not, there's your answer!
Hi,Andrew Neil : Thanks for your answer! Since I am a newhand and also not very clear about the English concept,perhaps I make some mistake in the explanation of the problem. However , your answer is very helpful to me! I really appreciate it. I will be careful!
