uCOSII to 8051 warning message.
I am using uCOSII V2.52
I am using the Keil C compiler V7.02
Large memory model.
Everything compiles but, I get one warning that worries me.
Not sure if I can post the uCOSII code or not, but if you have uCOSII V2.52 check out the file and line number below.
File Name: OS_TASK.C
Line Number: 174
Keil Warning #196 mspace probably invalid.
The keil warning #196 says (The conversion of a constant to a pointer constant yields and invalid memory space).
Maybe somebody has ran into this while compiling uCOSII with Keil 7.02 compiler. Any help would be apreciated. Thanks :)
