how to access pointer array located in BANKn?
Emergency
//Located at BANK0
code char *pStrArray[] = {
   "1",
   "2",
   "34",
//Located at BANK0
void LoadString(char *strbuf, const char *pString){
   BYTE iBank;
   iBank = get_bank();
   switchbank(RES_BANK);
   strcpy(strbuf, pString);
   switchbank(iBank);
//Located at BANK1
void GetString(char *strbuf, const char *pStr[], unsiged char i){
   LoadString(strbuf, pStr[i]);
//the result is null string, why?
  • if your constant string is located in a bank using a linker directive,
    When you pass a pointer to another function located in another bank you get something with no sense ( the string is not visible )...
    The solution is to make a function in the same bank of the strings witch copy the string in a buffer in ram: the buffer will be visible in all bank of code !
    i use this solution...
    Another solution is to use far memory support from keil witch manage this problem... but you need to use LX51 and fill in assembly the file l51_bank.a51 to configure the access to different objects(function ?C?CLDXPTR, ?C?CSTXPTR, ?C?ILDXPTR, ?C?ISTXPTR, ?C?PLDXPTR, ?C?PSTXPTR, ?C?LLDXPTR, ?C?LSTXPTR )
    regards
    christophe grun
    regards
    christophe grun
