Possible problem in START_V2.A66 chip select initialization
The chip select initialization code in START_V2.A66 enables the chip selects before the ADDRSEL registers are programmed. I was single stepping using OCDS and noticed the disassembly changed when CS1 was enabled. I moved the ADDRSEL initialization to before the FCONCS1 and TCONCS1 initialization and the problem went away.
