I am experiencing unexpected results when performing floating point arithmetic.
void main( void ) { long raw_value; float scaling_factor = 0.0762951; float scaling_offset = -1000; float result; for( raw_value = 65530; raw_value <= 65535; raw_value++ ) { result = ( raw_value * scaling_factor ) + scaling_offset; } }
I tried your code using C51 v7.01 and it worked correctly. What version are you using? I output the results through the serial port with:
printf("\nraw=%ld result=%.3f",raw_value,result);
