unexpected results in integer arithmetics
Hello experts,
to avoid a division, I use integer arithmetics. The unsigned int x which is in the range of 2000 is first multiplied by a number s which is 2048 plus/minus 1000 and then shifted by 11 digits which should replace a division by 2048.
unsigned int  near x;
unsigned int  s
 x = ( (unsigned long) x * (unsigned long) s ) >> 11 ;
For testing I used s=2048. The result should be (x*2048)>>11 = x, but what I get as a result is about 30 times too big, and all results for different values of x are multiples of 0x20.
Type casting problem?
Please help, I run out of ideas.
