Hello, For me, it's still not clear why the include files (.h) are treated in such a cumbersome way in the uVision2 Project philosophy. When you have a project and you create a group -for instance- called 'Header files' then you have to specify that those files are Text documents to be able to add it to your project. The file types in the file open dialog box do not contain something separate for .h files, whereas this is the case for e.g. .c, .a* and .src files. Could someone explain me why is this? Wouldn't it be more logic, user-friendly and convenient if the .h-files would be treated the same way as .c- or .a51-files? Rgds, Geert
For a start, there is no need to add header files to your project; you only need to add files which are used directly by the build tools (Compiler, Assembler, Linker). You can open a header file by just right-clicking its name in the #include line and choosing 'Open Document' However, if you do want header files to be treated as 'C' source, just go to Project/File Extensions, Books and Environment, and add "*.h" to the list for 'C Source File' Remember: if you do this and add your header files to your project, you must clear the 'Include in Target Build' option for the file and/or the group. I usually add the following filetypes: C Source *.h; *.i Document *.lst; *.map; *.m51
One more possibility is this: * Create a separate Source Group for headers * Add your .h files to as "C source files" * Go to the Options dialog for the und un-check the "Include in Target build" box. This will treat your header files as normal C files, as you edit them, but avoid compiling them separately.
You can open a header file by just right-clicking its name in the #include line and choosing 'Open Document' Hi Andrew, This would be nice, but it doesn't work always (at least, not in my case). Even if I build the target with the browse information generation activated, I have some strange effects. If I right-click on the include files I've made my own, I don't see the item 'Open Document "xxx.h"' in the popup menu. For instance, suppose I have the following include line: #include "i2c.h". If I then right-click on the word i2c, then I see the item "Go To Definition Of 'i2c'" instead. Using '#include <>' or '#include ""' doesn't make any differences. If I, however, just add a 'predefined' header file in my .c file (so, a header file which was provided by Keil), for instance REG52.H, then I see the item 'Open Document "xxx.h"' in the popup menu. My question: when is the uVision environment able to open the header files the way you described and when not? Is the location of the header files eventually important? Indeed, if this would work, then the need to have a separate section in your project with only header files would not be so big. Rgds, Geert
I arrived at the same solution as Hans-Bernhard. While I can put access to my important header files only a click away in this manner, it forces me to work around a limitation in the tools. Let's face it, people edit their header files occasionally, to change things, so we don't have to touch the source code. The uVision solution of having to open the C file, scroll to the "#include" reference for the header you want to work on, and then click on it, is tedious. Instead of the interface working like I do, I have to work like it does. It's a computer, for goodness sake. Perhaps a read of Alan Cooper's "The Inmates Are Running The Asylum" is in order. The fact that the ".h" extension was left out of the "Add files" dialog is almost spiteful: "You don't need to add header files so we'll make it difficult for you." I can't imagine the need to be so rigid here. The code generated by the Keil tools is first rate. It's the development environment that has some rough edges.
Note that all the headers used by a source file also appear in the project list, nested under that source file. Click the + box, and then double-click the .h file just as you'd double-click a .c file to open it. It's still not one global list of all headers, but you need not open up the .c file to open up a header file. My pet peeve in this area is that the uVision file add files dialog lets you choose "*.a" files, while the default extension for the A51 assembler is, well, .a51. uVision doesn't automatically recognize its own assember extension. C'est le code.
You'll like a new feature of the latest version, then. It has a list of all files #include'd by any compiled file as part of the project "Files" window. You click on the '+' to open up the sub-nodes, and select your include file from the list. OTOH, I can't quite follow you why the existing method is "tedious". It's a few more mouse clicks than to add a .h file to a project than a .c file --- so what?
""*.a" files, while the default extension for the A51 assembler is, well, .a51. uVision doesn't automatically recognize its own assember extension." I thought the default was *.a* - which does recognise .a51??!!
"You can open a header file by just right-clicking its name in the #include line and choosing 'Open Document'" Unfortunately, uVision doesn't use the Include Path for this facility - so it doesn't work if the .h file is not in the same folder as the .c file. :-( NEIDE (Not Entirely Integrated Development Environment).
