I generate a map file with the extension .m51. In this file, we can see the symbol table with three columns : VALUE, TYPE and NAME. In the first column (VALUE) we find the address. This address is preceeded by a letter (C for Code segment for example). Where can I find the signification of all these letters ?
Thank you for your help ! But this list is not complete : for example, I have the letter B for Bit segment I suppose and the letter N indicating the directive EQU is used. Is there any other letter ?
In the Macro Assembler and Utilities User's Guide, Chapter 2. Architecture Overview under Memory Layout. The tables list the address ranges including the letter prefixes for the memory spaces.
In the manual, there is no description about these letters !
Where else but in the manual!?
