I want to run the C166 monitor in bootstrap mode but have problems to get it running. Since the memory map is quite exotic, finding proper monitor configuration might produce some headache. But i do not think this is the problem, because the download even seems not to start. How can i see if the bootloader itself was loaded? Thank you.
The initial loader does not depend on any configuration settings. To see if the BSL mode works you can use MiniMon: http://www.infineon.com/cgi/ecrm.dll/ecrm/scripts/public_download.jsp?oid=11188&parent_oid=-8137 http://www.infineon.com/cgi/ecrm.dll/ecrm/scripts/public_download.jsp?oid=11189&parent_oid=-8137 MiniMon is somewhat easier to start working with and it's very useful for testing new hardware designs. Regards, - Mike
I just learned late last week that there is a problem in C166 V4.22 that affects the monitor program. If you are using this version you need to request a new linker. http://www.keil.com/support/docs/2366.htm -Walt
If you are using this version you need to request a new linker. Or, better yet. Download the latest update (4.23) which includes the latest linker. Jon
Thank you, but i'm using Version 4.25. I was trying MiniMon and the connection was estabilshed successfully. The problem is our exotic Hardware configuration which probably requires special actions to acess external memory. There is a GAL which manages having FLASH and RAM at the same adress space. Next i will take our own bootloader (made by our hardware developer) and compare it to the Keil bootloader. My main problem is that starting the monitor hangs up without any hint what was going wrong. If i knew if the first and second parts of the bootloader were loaded correctly i could check if installing the monitor fails. When running uVision with WinXP it hangs up completely, with Win98 the normal "CONNECTION TO TARGET SYSTEM LOST" message appears.
I don't know what instructions are necessary to address the FLASH or the RAM at the same address space. Any instruction can be inserted into the boostrap code. Usually different CS (chip select) signals are used for these different devices. Usually the monitor reports error messages when the monitor cannot be donwloaded. When I know the reason, I can fix it in the next version. Maybe it helps you to know how the monitor works: - uVision sends a 0 byte and waits for the bootstrap acknowledge byte from the microcontroller. After a timeout, a error messagebox pops up. - The first 32 bytes and then about 300 bytes are downloaded. The microcontroller acknowledges it with 0xAA - PC sends a command to calculate a checksum in the monitor area. The microcontroller sends it. - When the monitor was not loaded into memory before, the checksum will not match and the PC starts to download the complete monitor. During this time you see a progress bar running from 0 to 100% in the lower left corner. - PC sends a command to calculate the checksum in the monitor area again. If the checksum does not match, a error messagebox will pop up. If it matches, the montitor is started. - After a monitor start acknowledge, the application is downloaded. The progress bar is displayed again.
