I have implemented a new serial data transfer protocol in our 8051 system (80C552). I tryed to write the received characters immediately back to the terminal with the following commands:
ucrs232_buffer[ucrec_count] = S0BUF; S0BUF = ucrs232_buffer[ucrec_count];
Hi Christian, what is your SIO baud rate? There may be problem with SIO interrupt priority and corrupted terminal's STOP bits (especially for lower buad rates). 1. Compare both SIO settings. 2. Set serial interrupt to the highest priority as sole owner of the priority. 3. Maybe can help insertion of "short" delay between your two S0BUF lines for example (up to 1/2 STOP bit time which depends on your serial ISR length till S0BUF "actions" - It is necessary to tune it)
ucrs232_buffer[ucrec_count] = S0BUF; /* delay here */ S0BUF = ucrs232_buffer[ucrec_count];
Hello Vaclav, thank you for your answer! The baud rate is 9600. My OSC=15MHz -->9765bps. This is not so good but it worked with the old protocol, and i did not any changes at the interface settings. I use the external interrupt which occurs with app. 915Hz. I set this to priority level 0 and the serial interrupt to priority level 1 --> No changes at all.
if(RI) { if (ucrec_count >= 128) ucrec_count=0; //store data from S0BUF ucrs232_buffer[ucrec_count] = S0BUF; S0BUF = ucrs232_buffer[ucrec_count]; //if char equals <EOT>(0x04), set brs232_rec if (ucrs232_buffer[ucrec_count]==0x04) brs232_rec =1; ucrec_count++; RI=0; } return;
"The baud rate is 9600. My OSC=15MHz -->9765bps. This is not so good but it worked with the old protocol" Just because something doesn't fail doesn't meant that it's actually working properly! ;-) That sounds a pretty large baudrate error!! :-0 As recommended on the Keil baudrate calculator http://www.keil.com/c51/baudrate.asp "For the best results, you should choose baud rates that are accurate to +/-1% or better." I think you could just have been lucky that it ever worked!!
Thank you for your message and the baud rate generator. I tryed the baud rate 1200 with and error of +0,17% and I got the same result! Unfortunatly it was not the reason! Christian
