8032 idata upper address values
Micro: 80C32
C51 version: 5.20
I am currently working on a project where the head electrical engineer has asked how much stack our application uses.
Our application has a serial message server, and so I wrote a quick routine to query the internal RAM. After looking at the .m51 file, I knew our stack starts at memory location 0x5D, so I started querying there. It appeared that our maximum stack usage topped out at address 0x85.
Just for grins, I checked the values of each idata byte from that point all the way up to 0xFF -- the top of the internal RAM memory map, right? I got expected values (0x00) at each location up to 0xFB. From location 0xFC to 0xFF, I got values other than expected, as if something wrote those values there.
I can not find anything in our C-code that indicates a write to idata at these locations, so my question is this -- is there something that is normally written to the top of idata that I am unaware of -- something part of Keil, or 8051 derivatives, etc.?
