Dear Sir/Madam I am using uvision to plan a software project which SDA555X TVText Pro from Infineon has been used in it. Now the volume of the program has been reached larger than 64KBytes and uvision messages me the error. So, would you please advise me how i can manage the settings of the uvision to handle this situation. Thanks and best regards Faranak Mahjoobi
The SDA555x has on-chip banking hardware that is currently supported only by BL51. You need also a special library for this device. Please email your request along with your serial number to: support.intl@keil.com We will then send you details instructions on how to use code banking with this device.
Wow, I think you got your point across. :~) Maybe your mouse button is bouncing over the POST button.
I have C51 special Run-Time Libraries of SDA30C163. Can i use these libraries for SDA555x also?
The library version VERSION_6P03_FOR_SDA_30C163 can be used also for SDA555x.
