Placing size of array at start of array
Hi all,
I am working with the TI TUSB3200, trying to modify their example code for our own USB device. USB requires many tables which start with a length byte. I would like to use the sizeof operator to calculate this for me, as shown here:
byte code rictest[] =
	sizeof(rictest),
	1,
	2
This gives the error
warning C198: sizeof returns 0
, so plainly the compiler only does a single pass through the code, and does not know the array size until it has finished parsing the entire array definition. :(
Is there any other way to achieve this? I presume it would be possible with some sort of pre-processor macro to count the number of elements manually before defining the aray...
