void initialize_system (void) { // Initialize the serial port (9600, 8, N, 1) PCON &= 0xBF; // Clear bit 7 of the PCON register (SMOD1 = 0) SCON2 = 0x50; // 0101,0000 (Mode 1 and RxD enable) TMOD |= 0x20; // Timer #1 in autoreload 8 bit mode TCON = 0x40; // Set Timer #1 to run mode TH1 = 0xFD; // Baud rate is determined by // Timer #1 overflow rate // Baud Rate = (Fcpu / 384) / (256 - TH1) // Fcpu = 11.0592 MHz // TH1 = 253 TR1 = 1; // Turn on Timer 1 TI2 = 1; // Set UART2 to send first char } void main (void) { unsigned char aaa; initialize_system(); while(1) { aaa=_getkey(); printf("%c",aaa); putchar(aaa); } }
