void initialize_system (void) { // Initialize the serial port (9600, 8, N, 1) PCON &= 0xBF; // Clear bit 7 of the PCON register (SMOD1 = 0) SCON2 = 0x50; // 0101,0000 (Mode 1 and RxD enable) TMOD |= 0x20; // Timer #1 in autoreload 8 bit mode TCON = 0x40; // Set Timer #1 to run mode TH1 = 0xFD; // Baud rate is determined by // Timer #1 overflow rate // Baud Rate = (Fcpu / 384) / (256 - TH1) // Fcpu = 11.0592 MHz // TH1 = 253 TR1 = 1; // Turn on Timer 1 TI2 = 1; // Set UART2 to send first char } void main (void) { unsigned char aaa; initialize_system(); while(1) { aaa=_getkey(); printf("%c",aaa); putchar(aaa); } }
Eric, Thank you first for your suggestion. I have rewritten the putchar() and _getkey(). But it still had no response. I suspect the setting of my code. Thank you again.
I think _getkey(), printf() and putchar() in the library use first Uart in a standard 8051. If you to use 2nd Uart you must write a new _getkey() and a new putchar() in your application.
to Jon, Thank u first. I use the ST Microcontroller uPSD3234A. I can use Uart0 to exchange data with PC. But I can't echange date with PC by Uart1. I think my code must have some bug. Please help me. Thank u.
Since I'm not sure which chip you are using, I'll assume it's the Dallas 320. If that's the case, take a look at the following knowledgebase article: http://www.keil.com/support/docs/1324.htm Jon
