I have app. board with C166 and 128k RAM only connected to C166 by 8b demux bus. I try to configure monitor in Bootstarp mode. When monitor code starts from 0h then there is no problem. Trying to place monitor code somewhere else,let say 01A800h, causes a breaking of "debug session". Tracking a traffic on ASC0 I descovered that at the end of monitor's downloading process (a number of WRITE_MEM commands)there is no START_MON command coming out from PC. Also I was not able to find a code in Inst166.a166 that sets up interrupt table when monitors starts not from 0. Where is my mistake? Thank you.
I think there is a hardware problem on your board. Please download the monitor to address 0 and check if the memory at address 1A800 can be accessed by modifying some bytes. After uVision2 downloads the monitor, a checksum is built over the monitor address area to see if the download was successful. If the checksum is correct, the MON_START command is sent. It seems that the monitor download was not successful on the high address of your board.
Actually it was problem of linker v4.24 Keil informed. With version 4.20 there is no problem. Thank you.
