The DS1642 is an RTC + NVRAM The information is in centain memory locations in bcd format. Ok , so i made a simple program to display the minutes :
#include <reg51.h%gt; xdata minutes _at_ 0x07FA; //this is the memory location containing minutes xdata control _at_ 0x07F8; //this is the control reg void main() { while(1) { control = 0x40; //set the read bit putchar(13);putchar(10);putchar('m');putchar('='); //eye candy punchar(minutes); control = 0x00; //reset the read bit delay(100); } }
"Yes, I missed the fact that a data type was not specified." probably because that's how it was in the original post?
Yes, I missed the fact that a data type was not specified. Making the address volatile insures that the generated code will read the minutes location each pass in your while loop. -Walt
"What is the data type here?" In 'C', eveything is an int unless otherwise specified.
How does this work?
volatile xdata token_num _at_ 0x0010;
Give this a try:
volatile xdata minutes _at_ 0x07FA; volatile xdata control _at_ 0x07F8;
