Updated data on external EEPROM
Hello all,
I have a very complicated question 4 U.
In my target board I use the T89C51RD2 micro and also two types of external memory devices; SRAM 32KB and parallel EEPROM 8KB.
My code runs from micro's internal memory and from SRAM. The EEPROM is for data storage.
All my software is based on Keil's RTX51-Full operating system.
One of the project requirements is to save some data such as date and time for cases such as hw/sw reset, power down and etc. At this moment I only backup the data when I receive software reset. In this case I get the followings:
1. Data is saved also in hardware reset, despite the fact that I didn't handle this case.
2. Despite that data is saved at hardware reset, power off/on mode doesn't save the data.
3. If I saved the data (by entering to software reset) and then torn off and on target's power supply, data NOT saved on external EEPROM.
4. If I enter clock data (11:11:00 for example) to system (run in SRAM) but NOT save it in EEPROM and I press the hardware reset switch, system starts with current data value (11:11:10).
Can someone help me with that???
  • If you need to backup data on power down, your hardware has to be able to send powerdown signal to the MCU and maintain power supply for some time while EEPROM writes data (it usually takes several tens of milliseconds.) The MCU also has to be able to tell between different kinds of resets (power-up, hardware, software.)
    Besides that, I can't see what can stop you from implementing all you need.
    From your description it's hard to tell what goes wrong, if anything goes wrong at all.
    Regards,
    - Mike
    Regards,
    - Mike
