Using the uV2 command line switches to build several projects, it constantly opens the full UI of uV2. Can this be avoided and simply output compilation/linking text to the console? Also, are there any documention on the ERRORLEVEL values returned from an invocation of uV2, to allow exiting of a batch of builds when an error occurs? Finally, can the 'run user program' after build be prevented when an error occurs during the build? TIA
"can the 'run user program' after build be prevented when an error occurs during the build?" What version do you have? I asked Keil support about this once, and they said, "No." However, now that I have uVision v2.23 I note that it doesn't run the 'user program' when an error occurs during the build! (this is doing it in the IDE; dunno if it might be different from the command line)
Using make as recommended here: http://www.keil.com/forum/docs/thread1795.asp#msg7255 allows you to invoke the compiler and linker directly without using uVision, run a "user program" afterwards, and when errors occur during the build, stopping or not is at your option.
